Re-stamped Holleys? - NCRS Discussion Boards
Re-stamped Holleys?
  • Dan A.
    • May 31, 1974
    • 1074
    Re-stamped Holleys?
    How does one differentiate a re-stamped Holley from an original? Are there ways to tell one from the other?
    Dan
  • Dick W.
    • 10483
    Re: Re-stamped Holleys?
    If one of the better carb builders has restamped it, it is virtually impossible to tell. Some of the earlier restamps had a bulge inside the air horn where the stamps pushed the metal in, but the later ones are stamped over a mandrel. There are some small differences in the bodies and castings of the later carbs, but they are very minor.
    Dick Whittington
    • Joel Falk
      Dick,
      Do you mean restamp as in taking an existing date or model and changing it to another, or do you actually mean stamping an un-dated carb for the first time with a vintage date?
      If it is the former, who do you recommend? My 67 has a service replacement carb that I'd like to see with a correct date.
      thanks
      Joel
      • Dick W.
        • 10483
        Joel, there are several that can change the date. I hesitate to recommend anyone in particilar, but I will tell you the best are the ones you never see advertisements for. They depend on word of mouth advertising and are always backed up several weeks/months.
        Dick Whittington
