C3 Battery Compartment Seal - NCRS Discussion Boards
  • Matthew S.
    • August 31, 2005
    • 64
    I have a 72 that I'm restoring the rear storage compartments on. My question is do the screws in the battery compartment (three large chrome screws in back, two smaller screws on the side and teo in the front) go through the seal or are should they be under the seal? When I removed the compartment trim I only had the back portion of my seal remaining and the three chrome screws went through the seal. However, a friend has the same car as mine and the screws on his are under the seal. Any help is appreciated.
  • John C.
    • January 1, 2005
    • 616
    Re: C3 Battery Compartment Seal
    They are under the seal on my 68.
    John
      • 15601
      Under the seal on my 1970.
      • Tom H.
        • May 31, 2003
        • 89
        They are under the seal on my Dec. date 72 coupe.
        • Dick W.
          • 10483
          Under the seal on one owner 11/71 build '72
          Dick Whittington
          • Matthew S.
            • August 31, 2005
            • 64
            Looks like it's unanimous, under the seal they go!!!
            Thanks for everyone's response.
            • Rob C.
              • August 31, 2004
              • 144
              Re: C3 Sealant Foam
              Is the seal continous or split?
              • Harmon C.
                • August 31, 1994
                • 3228
                Re: C3 Sealant Foam
                My vote is for split.
                Lyle
                Lyle
                  • 43221
                  Re: C3 Sealant Foam
                  Rob and Lyle-----
                  Definitely SPLIT. However, if you happen to get a reproduction which is not split (i.e. die cut as non-seamed) and you insist on 100% originality, it's quite simple to do. You just take a razor blade and carefully slice it near the middle of the bottom longitudinal section! That's all there is to it.
