I'd like to replace the mast in my 62 antenna with an NOS one I bought some years ago. Does anyone have information or instructions on how to do this? I've researched quite a bit and find nothing. Any help is appreciated. Thanks Rich
62 antenna repair
Tags: None
- Top
Re: 62 antenna repair
Rich--
Very simple to do. Remove the bottom tubular extension. There should be access to a black plastic piece that fits on the bottom of the mast. Once you've unclipped that, the mast will come out the bottom very easily. Just pull it down and through.Installation is simply a reverse of the above.
Good luck!
Mike- Top
