Gas Tank for '53-55 - NCRS Discussion Boards
Gas Tank for '53-55
  • Charles C.
    • May 31, 1978
    • 65
    Gas Tank for '53-55
    The only new gas tank I find availabe to 53-55 Vette owners is a stainless steel tank costing $595, which does not look like the original.
    Why don't 53-55 owners use the $219 '57-62 tank. For 15 years I thought it was because they would not fit the '54 gas tank compartment but tried my old '61 tank in my 54 and it fits fine. I know the sender unit on the 54 is (I believe) located in the center, not off center, but that should not be worth $300.
    Am I missing something?
    Charles
  • Roy B.
    • February 1, 1975
    • 7044
    Re: Gas Tank for '53-55
    No your not missing anything , just block off the vent line also. But again may be judges will make owners remove the tank cover to inspect it.???????? You think? I dont!
    • Kent K.
      • December 1, 1982
      • 1139
      Roy is absolutely correct. Judges will not be removing the gas tank cover to look at the gas tank. Use the '56-62 tank and modify it for your car.
      Kent #6201
      Kent
      NCM Founder - Member #718
