69 starter model number ??? - NCRS Discussion Boards
  • Frank Bernier
    Hi guys
    what would be the correct model number for 69 vette starter
    for a december 68 production car with a 427 and 4 speed
    thanks alot Frank
    • 43221
    Re: 69 starter model number ???
    Frank-----
    GM #1108400.
    • Frank Bernier
      what is 1108418 ???
        • 43221
        Addendum
        The above assumes that the car is not an L-88 or ZL-1. They used a different starter.
        Anyway, the 1108400 starter is a high torque starter with cast iron nose. It's designed for use with 168 tooth (i.e. 14")flywheels. Any high torque starter with the proper cast iron nose will be 100% functional for your application, though. Aside from "numbers", you don't need the 1108400.
        By the way, the 1108400 is a fairly difficult starter to find, especially with correct dates for your car.
        • Frank Bernier
          Re: Addendum
          can a 1108418 be dated september 68 ?
          and is it possible to be original to a L-68 400hp 69 vette ?
            • 43221
            Frank-----
            GM #1108418 was used for 1971-72 applications as far as Corvettes go. However, it was used for other Chevrolet applications beginning with the 1968 model year and through, at least, the 1975 model year. It is identical to the 1108400 in every respect that I can find; I have no idea why there were 2 different part numbers.
            There is absolutely no reason that I can find that the 1108418 could not have been used for Corvette applications as an alternate to the 1108400. However, I don't think that it's recognized as original for 1969.
              • 43221
              Re: Addendum
              Frank------
              Yes, an 1108418 could be dated 8/68. The starter was being produced at that time.
              Is it possible that it could be original to a 1969 L-68? I'd say it's VERY possible. I don't think that it's recognized as original for 1968-69, but I see absolutely no reason why it could not have been used in PRODUCTION alternately with the 1108400. As I mentioned above, as far as I can tell, the 2 starters are absolutely functionally identical.
              • Mark #28455
                didn't 8418 originally have aluminum nose? *NM*
                  • 43221
                  Re: didn't 8418 originally have aluminum nose?
                  Mark-----
                  No, it did not originally have an aluminum nose. There may be starters out there now that have a frame with the number 1108418 and an aluminum nose, but they didn't originally have that nose. The nose used for the 1108418 starter was GM #1965721. This was a cast iron nose using offset, "long" starter mounting bolts.
