Identify early bbc smog stuff...... - NCRS Discussion Boards
+ More Options
Posts
  • Terry F.
    • September 30, 1992
    • 2061
    Need some help identifying some 67 big block corvette smog hoses. Recently, there was a picture posted of a 67 bb with a smog set up on it. It prompted me to dig out some stuff that I had not identified. If someone has a clue about it, please let me know. What have is this:
    One diverter valve that has a GM33547 samped on it. It may have more numbers but there under the hose.
    Hose leading from the diverter valve, about 1 foot long, three ribs, no part number that I can see??
    Hose GM3889379RJ (not sure about the 9, could be an 0). I believe it went to one of the gulp valves.
    hose 8902340UA GM or 3902340UA GM. I can't tell if the first number is an 8 or 3??
    There is a "Y" shaped gulp valve and a standard gulp valve and a passenger side exhaust injector tube. About 4-5 tower clamps dated 1/67. All nice stuff. Help would be apprecitated. Thanks, Terry
    • 43247
    Re: Identify early bbc smog stuff......
    Terry----
    The mixture control valve (diverter) valve identified by number "33547" is a 1967 Corvette with 427 and K-19 piece. The complete part number, usually not found on the valve, was GM #7033537. However, this valve was also used for 66-67 passenger cars with big block.
    The hose part numbers of GM #3889379 and GM #3902340 are not the part numbers I show for a 1967 Corvette big block with K-19. Part #3889379 and 3902340 were used for 1966-67 and 1967, respectively, for passenger cars with big blocks.
    So, I'd say what you have here are K-19 parts from a 1967 passenger car with big block. However, as I mentioned, the mixture control valve (diverter) is the same as Corvette.
    • Terry F.
      • 2061
      Cool! I assume the air tubes that feed the intake are same for passenger or corvette. I saw a picture of them and they looked identical. Thanks for taking the time to do that. Best regards, Terry
        • 43247
        Terry-----
        The manifold pipe assemblies are the same for 66-67 passenger and Corvette with big block.
