1965 7-Blade A/C Fan Identification - NCRS Discussion Boards
  • James W.
    • December 1, 1990
    • 2655
    Hello,
    Can someone post or send me a picture of an original 7-blade fan for a/c equipped 1965 Corvette? EBay auction #280081771919 has a 64-66 advertised for auction, but it does not have the correct 3853943 p/n on on it as described in the 1965 Judging Guide. I have an original 1965 a/c equipped car but the 7-blade fan I have does not have the correct p/n either and does not look like the one in the EBay auction. The ends of each fan blade that I have are shaped kind of like a pyramid but with a flat or straight tip and has the letter "W" on one side and the letter "H" on the other side. The rivets are flat, not rounded of mushroomed like others.
    Any help would be greatly appreciated, send any all pictures to me at jwest@oppd.com.
    Best Regards,
    James West
  • Peter L.
    • May 31, 1983
    • 1930
    Re: 1965 7-Blade A/C Fan Identification
    James - I've seen a number of 64-65 Corvettes with C60 and so far none have had the configuration of the 7-blade fan on eBay. In discussions and observations the "original" 64-65 C60 7-blade Corvette fan had the "unique" fan blade end configuration with the angled cut and flat top tip that you describe with a bend in the blade near the tip and as show in Noland Adams' 63-67 book, page 218 as p/n 3853943.
    An interesting note is that from my experiencce and that of others there were 2 versions of the 3853943 fan blade assembly with the difference as best I could tell being the shape of the head of the rivets. One had the flat button rivets and the other version had the round mushroom head rivets.
    I have one with the flat button head rivers and it has a H and a 6 or 9 stamped on front face of the center portion of the support and a W stamped on the back of one of the triangular support sections that attach to the blade.
    Also, note that the Chevrolet Parts and Accessory Catalog does list the 7-blade, p/n 3853943, for 1964-1966 sb Corvette w/ C60, but Noland's book indicates 64-65 and that is consistant with my experience and the judging manuals. The 66 judging manual indicates that "There are undocumented cases of 7 blade fans used on air-conditioned cars."
    Hope this helps. Pete
    • Wayne M.
      • March 1, 1980
      • 6414
      eBay fan is wrong for '65 A/C
      7-blade fan below is what is correct for 1965 (and probably '64; can't say for 1966). This one has mushroom heads on the rivets (per '65 TIM&JG, but I understand later cars may have flat heads). There are no stampings on rear side of the hub or blades. Can't remember if anything on the front (not going to take it off to see).
      A few things about the eBay fan. Wrong blade tip contour; should not be an indented area on the front of the blade where the rivet heads are. The part #'s quoted in the Tech Manual can be used for X-reference to the dwgs in Noland's Vol 2. No numbers on blades.
      Probably more features that others can describe. Sounds like yours is like mine, below.
      • Grant W.
        • December 1, 1987
        • 407
        The fan on ebay 7 blade is for an Impala 409 or something like that. Not a corvette fan at all. I do have the same fan and I can make it a corvette fan for you. LOL. Grant
        • Michael M.
          • November 1, 2001
          • 411
          Re: eBay fan is wrong for '65 A/C
          Hi Wayne, You don`t happen to know your upper pulley no. and if it was original do you? Interested in all 65 C-60s for reasearch. Thanks, Mike
          • James W.
            • December 1, 1990
            • 2655
            Re: That's Exactly What I have on My Car!!! *NM*
            • Peter L.
              • May 31, 1983
              • 1930
              James - The sequence of responses is such that I'm not sure as to which fan blade assembly is on your '65 w/ AC. Is it the fan blade assembly Wayne had a picture of or the eBay fan? Inquiring minds want to know. Pete
              • Wayne M.
                • March 1, 1980
                • 6414
                Upper Pulley # 3848904 on my L76 - C60 ...
                ... an early car 014xx. But Mike, this doesn't agree with the AIM (UPC C60, Sheet 2) which calls for 3850979. This latter number does not appear in my parts catalog P&A30 Rev July 1965, but the W.P. pulley for the non-L76 # 33850680 does show in this service, and the "904" also shows for L65 w/C60.
                I've had my car for 25+ years and I don't think any of the previous owners would have changed it. The part # is stamped on the pulley. Strange thing is that the pulley had orange paint under the black pulley paint.
                Let me know if there's anything else you'd like to know on this car.
                • Michael M.
                  • November 1, 2001
                  • 411
                  James, I have your number recorded but when Wayne mentioned he had the same setup I had to ask what his was also. I would like to find out the car serial number that GM changed to the 0419 pulley if possible. Thanks, Mike
                  • Michael M.
                    • November 1, 2001
                    • 411
                    James and Wayne, Both of you have the 3848904 water pump pulley on your C-60 cars. {of course you both knew that] which also agrees with Joe Lucias research on this also. I think this is good enough proof that this is an original correct number.Joe states that this pulley was discountied many years ago and was replaced by GM#3995641 which is still available from GM. I have this pulley. I will try this on my engine even though I still don`t think I have the correct bottom pulley setup to match. The power steering pump pulley appears to have to be the GM #3770509 stamped pulley. The add-on power steering pulley is the GM #3751232 I think which I have. Thanks to all for the info so far. I need to confirm the lower balancer pulley for sure and I think we will have it nailed down. Those of you with original cars don`t know how lucky you are. I don`t think a lot of his is going to agree with the AIM. If it does I just don`t have enough sense to read it correcly. Mike
                    • James W.
                      • December 1, 1990
                      • 2655
                      Pete,
                      I have the same fan that Wayne has pictured in his post, EXCEPT my fan has the flat rivets, my car is a late build car VIN 22095. I'm glad to find out that for the most part I have the correct fan, other than the Judging Guide says that it should have the 3853943 part number stamped into it. Would you say that the '65 Judging Guide is in error or just need some clarrification regarding later built cars? This car has been in my family since 1974, and the only thing that has been done to it buy us is a repaint in 1978 and engine overhaul in 1980, the car currently shows 67,623 miles on the odometer and the odo has worked the entire 30 plus years we've owned it. I would not think that the fan was changed, at least not a long as we have owned the car. I have found that the fan clutch was replaced with a correct bi-metallic type clutch with the following info and date code C5 AE-A 2 8 67 SC and the radiator was replaced with a correct Harrison service replacment radiator dated 65J, again before we owned the car. When I stripped the original Glen Green paint there was no evidence of front end damage, so I know the the radiator fan clutch repalcement was not done because of an accident.
                      James West
                      Omaha, NE.
                      • Wayne M.
                        • March 1, 1980
                        • 6414
                        My reading of the '65 TIM&JG (5th ed.) ...
                        is that they do provide the part #s for all 3 designs of 1965 MY fans (non-air, C60, and 396) but dont specify in so many words that these numbers are to be found on the blade assy's. This is strange; why would the numbers be quoted if not to visually verify the part by number on the judging field ? I guess this is just the "tech information" part of TIM&JG.
                        I also have a mid-64 non-C60 fan (#3770529) & clutch and just checked and all I see is the letter "H" stamped into the center hub on the forward face.
                        • Michael M.
                          • November 1, 2001
                          • 411
                          Sorry for Hi-Jacking part of your Fan info Request
                          I didn`t mean to butt in but couldn`t help myself. I`ll try to do better. Mike
