Big Block Water Pump -'66 A.I.R. - NCRS Discussion Boards
  • Mark P.
    • July 31, 2003
    • 407
    I am looking to restore my 66 427 390hp water pump back to original and am unsure what the bypass hose configuration looks like. I ordered A.I.R. and they send me A/C. Go figure. Does anyone have any pictures out there? Since the outlet is a 90 degree turn, I would imagine that it's a direct shot to the engine from there, but would love to see the actual real deal.
    If it is a straight shot like I think, anyone know where to get a bypass hose, or do I just cut the one I already have to fit?
    Thanks for the help,
    Mark
    Mark Pugmire
    54 Pennant Blue
    56 Cascade Green Dual Quad
    56 Arctic Blue Dual Quad
    66 Nassau Blue 427 L36 Convertible
    67 Marlboro Maroon L79 Coupe
    • 43221
    Re: Big Block Water Pump -'66 A.I.R.
    Mark-----
    Reproductions of the fittings and hose are available from the Corvette parts sources.
    • Mark P.
      • July 31, 2003
      • 407
      Joe,
      I have the fitting, but have had some issue with the hose. That's why I was looking for at least a picture of what it should look like, if possible.
      Mark Pugmire
      54 Pennant Blue
        • 43221
        Mark----
        It's a "U"-shaped, molded hose.
        • Mark P.
          • July 31, 2003
          • 407
          Joe,
          Excuse my ignorance, but since I've never seen an original setup close up, I have the "u" shaped hose, but I have no idea how it works with the pump. I recently purchased the right pump, but have to have the old fitting removed and will need to install the new right angle fitting. I just guessed that it came up out of the water pump and went straight into the engine. Maybe I have no imagination, but how does the u shaped hose work with the correct fitting?
          Mark
          Mark Pugmire
          54 Pennant Blue
          • Mark G.
            • March 1, 2001
            • 227
            Mark, you have mail - *NM*
              Mark -
              Here's a '67 BB with A.I.R. and the U-shaped bypass hose from the pump to the intake.
              • Douglas L.
                • August 31, 2003
                • 299
                Re: Big Block Water Pump -'66 A.I.R. *NM*
                • Douglas L.
                  • August 31, 2003
                  • 299
                  Mark,
                  The 90 degree angled fitting that fits into the top of the water pump should be turned slightly toward the front of the car:
                  I used some emery cloth and some wet/dry sand paper to take the edge off the fitting where it press fits into the water pump to eliminate any scoring of the water pump surface. I also used some thread sealer. It pressed in no problem -no leaks.
                  Doug
                  • Mark P.
                    • July 31, 2003
                    • 407
                    John,
                    From the picture, it looks to me like I have another issue. No wonder I couldn't figure it out. The fitting coming out of my intake manifold is also incorrect. It runs straight out of the front toward the water pump. So do I need two of the right angle fittings? The one out of the water pump is pressed in, but the one out of the manifold is threaded. Am I guessing incorrectly again? My car was converted from being an original A.I.R. car and I am trying to get it back to original without a model to pattern it after and it's proving to be a little tough to figure out at times. Thanks for the picture....very helpful, but it does create more questions for me. Not that I'm complaining! I really do appreciate it.
                    Mark
                    Mark Pugmire
                    54 Pennant Blue
                    • Mark P.
                      • July 31, 2003
                      • 407
                      Thanks, Doug for the pictures. So what about the fitting that comes out of the manifold? Is it supposed to be threaded and also an elbow, I assume? Mine is currently straight (see my response to John above). I do have the correct fitting to put in the water pump...but I have never pressed one in. What equipment is needed and could I do it myself?
                      Mark
                      Mark Pugmire
                      54 Pennant Blue
                      • Mark P.
                        • July 31, 2003
                        • 407
                        Re: Mark, you have mail -
                        Mark,
                        Sorry, no access to the other e-mail address for the next few days. Only the one listed here: Mark_KaylenePugmire@msn.com. Thanks for your help.
                        Mark
                        Mark Pugmire
                        54 Pennant Blue
                          • 43221
                          Mark------
                          The 90 degree elbow fittings are required at both the waterpump bypass and the front of the intake manifold. For your application, I believe that BOTH of these are a press fit. The '284' waterpump uses a press fit-type fitting and your manifold, if original, should use a press fit type fitting, too. I believe that the reproduction elbow fittings available for your application are press-fit only.
                          After 1967, the special AIR-only big block waterpump bypass set-up was eliminated. It was not until later yet that the waterpumps and manifolds went to a threaded fitting. So, there's no reason for the reproduction source to manufacture a threaded 90 degree elbow fitting.
                          • Douglas L.
                            • August 31, 2003
                            • 299
                            Mark,
                            The fitting on the manifold is also a right angle fitting. I believe, but not 100% sure, that it is also a press in fitting. I got this information from the PARAGON catalog which states the bypass fitting for both the water pump and the intake are press-in. I did not have to deal with the manifold fitting on my car, but it looked as if it was a press in fitting. The motor in the car has never been apart, other than the water pump and starter.
                            I did not use any special tools putting the angled fitting into the water pump. I lined the fitting to the pump. Then, with a small piece of wood over the top of the fitting, I tapped it into place. I think you could easily do it yourself. But, as I said above, I used emery cloth and fine sandpaper to take the rough edge off the elbow fitting.
                            Now, having said all that above relating to my car, I have friend that has a 66 - 427 A.I.R. car and the fitting into his manifold was threaded. So, threaded, press-in, or either on the manifold - I am not sure. Maybe some other guys can weigh in on this.
                            Doug
                              Paragon has the special press-in 90* fitting that goes in the front of the intake - their #1623, $25.00.
