63 Glovebox Light Ground - NCRS Discussion Boards
  • Seth McCulloch
    In putting back together the glovelbox assembly for my early '63 I'm not sure about how to ground the glovebox light. I can't find any information in the guides or manuals about where a ground should go. However on the brace below the box (where the trim tag is affixed to but closer to the center console) there appears to be a small hole that would be perfect for attaching a ground wire with a screw. Can anybody confirm or deny that this is the right approach? Thanks much,
    Seth
  • James J.
    • June 30, 2005
    • 77
    Re: 63 Glovebox Light Ground
    Seth, that is where my Oct "62 is attached. Hex head self tapping screw painted black.
    Jim
    • Mike M.
      • May 31, 1974
      • 8385
      i believe ground is accomplishied by the light's housing being a press fit in the metal frame of the glove box door which is fastened to the brace the vin/trim tags attach to. i don't recall an area on the light housing that has provisions for a ground wire. sure ya have the correct glovebox light assembly? mike
      • James J.
        • June 30, 2005
        • 77
        Mike, not sure about later 63's but early 63 have no metal frame for the glove box. Just a fiber box secured to the fiberglass dash. So a ground wire is attached to trim tag brace.
        Jim
        • Harry Sadlock
          Later 63's, April, the ground is from the glove box frame to the Z bar that has the Vin and Trim plates.
          Harry
