Big Block Motor - Any Details? - NCRS Discussion Boards
  • Joel T.
    • April 30, 2005
    • 765
    Hi All...
    I've got a big block Chevy motor which came out of a 1965 Vette which I picked up last summer. I was wondering if anyone could shed any light on what this really is...
    Casting number is 3999290
    Casting date is J 4 71
    Pad T1007THB with no Vin# stamped
    Pistons 2347P marked .030"
    Near as I can figure this is a 402 replacement for the original 396. I have not pulled the pan but I assume this is a two bolt main set up.
    Any ideas as to what the compression rating of the pistons is, or any other details, or what might be an appropriate application??
    Thx, Joel
  • Edward M.
    • November 1, 1985
    • 1922
    Re: Big Block Motor - Any Details?
    Looks like a 1972 402 210hp, installed in a truck, 4 bbl carb.
      • 43221
      Joel-----
      I don't think that the 3999290 block was ever originally manufactured with 4 bolt mains, so your assumption is probably correct. However, it can be rather easily CONVERTED to 4 bolt main configuration.
      The pistons identified as "2347P" are stock type, Federal-Mogul/Sterling conventional cast pistons. With stock heads they will produce a compression ratio of right at 8.5:1. These are obviously for a .030" overbore, so the actual compression will be slightly higher than 8.5:1.
      How did the motor run when you got it? Was there any problems with pre-ignition? With this kind of compression ratio there should not be, but big blocks have a great tendency to that condition, even at relatively low compression ratios.
      • Joel T.
        • April 30, 2005
        • 765
        Joe,
        Thanks for the information. I ran this motor in the car for only a short period of time and did not notice pre-ignition, but again the thing had a set of (after market) side pipes so I could not hear much other than the roar! It ran OK but not what you would expect from what was supposed to be a 425HP motor. It also had a set of oval port BB heads which I believe were from a later model 427/425 (3919840 B-18-9 casting date). What I am basically doing here is trying to figure out what to do with this motor... For the '65, I've found a correct block (resto) and a set of 208 heads with correct date codes so I have that covered. If this motor is worth some work I might look to find something (cheap) to put it in!!!
        Joel
        • Mark #28455
          840 heads are worth some $
          The block is nothing special but the heads are in demand by restorers for Corvettes, 375 HP 396's and COPO Camaros. The heads alone could bring $1000 or more a pair. Sell them and pick up a mid 1970's 454 core for about $400, then you have $600 to use on the rebuild. An oval port 454 will pull much harder than the 396 (especially with rectangular port heads). Just make sure you use a SHORT duration hydraulic cam.
          Mark
