C2 Air Conditioning - NCRS Discussion Boards
C2 Air Conditioning
  • Gary W.
    • August 31, 2000
    • 48
    C2 Air Conditioning
    Does anyone know where I can get a wiring diagram for the air conditioning system on a 66? Thank you.
  • Mike M.
    • May 31, 1974
    • 8396
    Re: C2 Air Conditioning
    should be in the assembly manual availble from NCRS. mike
      Hint:
      Look in the rear section of the AIM under C60, Air Conditioning option, for the wiring diagram details that apply to the added option vs. the base car...
      • Wayne M.
        • March 1, 1980
        • 6414
        66 Chev Chassis Service Manual; clearer than AIM
        This applies to ALL wiring diagrams --- I rarely use the AIM versions.
        • Gary W.
          • August 31, 2000
          • 48
          Re: 66 Chev Chassis Service Manual; clearer than A
          Wayne: You are the bomb!! Thanks so much.
          • Gary W.
            • August 31, 2000
            • 48
            Mike: Didn't find any wiring diagrams under C 60??
            • Gary W.
              • August 31, 2000
              • 48
              Re: Hint:
              Jack: Didn't find any wiring diagrams??
                Gary -
                Try the C60 section, sheet E9 for the A/C wiring diagram.
                • Gary W.
                  • August 31, 2000
                  • 48
                  I will look for it. Thanks.
                  • Verle R.
                    • March 1, 1989
                    • 1163
                    I agree with Wayne, the Chevrolet Service Manuals have better diagrams and are much clearer than AIM diagrams.
                    Verle
                    • Gary W.
                      • August 31, 2000
                      • 48
                      John: I finally found the wiring diagram with your help. Why don't they make the index in this guide a little more informative?? Anyway, thanks very much for your help.
                        Gary -
                        The Assembly Manual was an Engineering document, so the parts are arranged by their UPC (Uniform Parts Classification) groups in the base car section, and by the alphanumeric RPO code number in the option section, the way they were released by Engineering. Each section has a "contents" sheet at the front so you'll know where (on which sheet) to find the part(s) you're looking for. In the C-60 section, the first sheet (A1) has the contents of that section at the top, where it shows sheet "E9" as the Wiring Diagram.
                        • Gary W.
                          • August 31, 2000
                          • 48
                          Wow! Is there anything you guys don't know?? Thanks again.
