C2 1965 jack - NCRS Discussion Boards
C2 1965 jack
  • David H.
    • October 25, 2006
    • 92
    C2 1965 jack
    How would I identify the proper jack for a '65 built in Nov. '64. I believe it takes a "type 1", but not sure how to id it. Thanks
    David Hobby (46447)
  • Rob A.
    • December 1, 1991
    • 2126
    Re: C2 1965 jack
    Dave,
    If you have the Noland Adams book...check out page 105. If your car is an early '65, it describes yours as having a solid handle(no holes)wrench assembly. The jack looks like it could have been one of a couple different variations, and would have a sealed ball bearing set up as opposed to the nylon washer sandwiched between two steel washers. Maybe the '65 juding manual has more specifics.
      Yes...
      the JG book adds details. Both Type 1 and 2 jacks have the ball bearing vs. acetal resin bearing assy. But, the type 2 jack is identified by having reinforcement ribs on its lift arms while the type 1 jack is constructed of essentially flat stamped steel components.
      • David H.
        • October 25, 2006
        • 92
        Re: Yes...
        There is a jack on eBay,item 160084561795, is this a type 2?
        David Hobby (46447)
        • Tom H.
          • December 1, 1993
          • 3440
          Re: Yes...
          No, that is a C3 jack. ( Ebay item 160084561795 ) I will try to post a good picture of my type 1 jack for you when I get home tonight !!
          Tom Hendricks
          Proud Member NCRS #23758
          NCM Founding Member # 1143
          • Tom H.
            • December 1, 1993
            • 3440
            Re: Yes...
            Here is my type 1.
            [/IMG]
            Tom Hendricks
            • David H.
              • October 25, 2006
              • 92
              Re: Yes...
              Many thanks for the help! I've got a Nolan Adams book on order so might help on details. Thanks again!!
              David Hobby (46447)
              • Eric O.
                Infrequent User
                • May 31, 1988
                • 6
                Re: C2 1965 jack
                2 Questions:
                1. Is a type 1 or type 2 jack correct for a 1965 vette built on Dec 28, 1964?
                2. Does anybody have a picture of a correct type 2 jack that I could share?
                • Tom H.
                  • December 1, 1993
                  • 3440
                  Re: C2 1965 jack
                  Eric:
                  I don't have a type 2 picture, but if you look at the picture of the type 1 I posted, the difference on the type 2 is on the trunion end. ( upper left hand side of my picture ) The trunion "u" is inverted instead of being outward on a type 2. The type 2 jack is just a tad shorter, due to this feature. Also, the type 2 has gussett reinforcements for strength on the lifting arms. To the casual observer, they look very much alike. I'll check my judging guide for correct application for you when I get home. It seems to me the cutoff for type 1 on a 65 was VIN # 12000, but can't be for sure until I see the JG. Will report later if no one chimes in with the info.
                  Tom Hendricks
                  • Tom H.
                    • December 1, 1993
                    • 3440
                    Re: C2 1965 jack
                    I was wrong on the VIN # 12000 cutoff for type 1 jack. My older 65 JG says type 3 was introduced after VIN 20000. I does not say when type 1 and 2 are to be used. I do know my February built 65 had a type 1.
                    Tom Hendricks
