c2 steering column capacitor - NCRS Discussion Boards
  • Jim R.
    • June 30, 2001
    • 643
    can anyone tell me what the big capacitor is under the dash ,just left of the steering column on a 65 ,the one on my car is not hooked up to anything ,it is two inches long with 2 long black leads and the diameter of a nickel , is this for some option my car does not have.?
    JR
    • 43221
    Re: c2 steering column capacitor
    Jim----
    Most likely, it's the radio interference suppression system capacitor originally connected to the brake lamp switch.
      Jim -
      That's a radio noise suppression capacitor for the stop light switch - check your assembly manual, section U69, sheet A5, top right illustration.
      • Jim R.
        • June 30, 2001
        • 643
        thanks guys, Ill hook it back up!
        JR
          Sometimes, the radio RF cap on the brake light switch was intentionally disconnected by prior owner/mechanic because the cap was bad causing fuses to blow when the brakes were applied... Disconnecting the cap was an el-cheapo 'solution' to replacing it!
