1970 Gas Cap Question - NCRS Discussion Boards
    • 43221
    Re: Sorry, Joe...
    Chuck------
    Karnac no reveal his secrets.
    • Zachary K.
      • March 1, 1986
      • 162
      Re: Sorry, Joe...
      My very late 70, (499th from the last serial number) which I purchased in 73. Came with the gold cap with the label (71 cap). Years ago, I purchased the silver cap with Sealed as that is what the judges were looking for. Now when showing I just ask which cap they want to see and pull the other cap out of my back pocket. I do leave the Gold cap that I believe is original to the car on all the time. I have also found that other items on my car are 71 also such as turn signal and tilt levers.
      1967 L79 Sunfire Yellow Black Leather Convertible- Duntov
      1969 L71 LeMans Blue, Bright Blue Convertible
      1970 L46 Monza Red, Light Saddle Convertible - Duntov
      1976 L82 Classic White, Firethorn
      2013 LS7 Black, Ebony, Convertible
      Moved on -
      2006 LS2 Black, Ebony, Convertible
      • Gerard Q.
        • February 1, 2000
        • 284
        #18
        Re: 1970 Gas Cap Question
        To further the discussion this is a pic of the gas cap on my 71 with a build date of May 26, 71.
        • Warren F.
          • December 1, 1987
          • 1516
          #19
          That is the same style cap that is on my March 18th and April 20th built '71's.
          • Carr C.
            • March 1, 2004
            • 86
            #20
            Chuck,
            Thanks for your input. I enjoyed meeting you in San Antonio and really appreciated you answering all of my questions when you where judging the gray '70 convertible.
            I learned quite a lot from my first NCRS event, and most of it was because you took the time to help when I had a question.
            Joe,
            You are the Karnac of Corvettes! Every time I have a question, you have an answer. You'll be happy to know that I found an original, correctly dated, '70 LS5 clutch fan and fan blade. Thanks for the pictures and the details to help me!
            I also appreciate everyone elses input. It's great to get all the angles.
            I'm not sure if I'm just lucky, but I always get a very good response to my posts!
              • 43221
              #21
              Re: Sorry, Joe...
              Zachary------
              Can you post a picture of the cap that was installed on your 73 when you bought it? I'd like to see it.
                • 43221
                #22
                Carr-----
                While I may always have an answer, it may not always be the correct answer. That's why it's so good to get the input of others. I often learn as much from it (or, from the research that it spurs me to do) as anyone else. This 70 gas cap thing is a perfect example.
                • Zachary K.
                  • March 1, 1986
                  • 162
                  #23
                  Joe. Sorry if I created some confusion. My car is a 70 which I purchased in 73. I just made mention to the year I purchased it as it hadn't changed hands much before that and it has been in my posession ever since.
                  Moved on -
                    • 43221
                    #24
                    Jerry and Warren-----
                    That's very good information. Apparently, the 3983384 cap was used for a longer period than I thought. There's absolutely no functional reason that it could not have been used, though. All 3 of the caps we discussed previously are functionally identical and 100% compatible with any 1970-71 Corvette.
                      • 43221
                      #25
                      Re: Sorry, Joe...
                      Zachary-----
                      It was me that created the confusion. I meant to say can you post a picture of the cap that was on your 1970 when you bought it in 1973?
                        • 11643
                        #26
                        Same as my June 15th built 71.
                        Patrick
                        • Chuck S.
                          • April 1, 1992
                          • 4668
                          #27
                          Carr, it must have been another Chuck in San Antonio...unfortunately I didn't attend the San Antonio National. The last time I judged was at the 2005? Waco Regional. But, it is good to hear my namesake took the time to answer your questions in the finest tradition of the NCRS.
                            • 15601
                            #28
                            • Lyndon S.
                              • April 30, 1988
                              • 1027
                              #29
                              Thanks Terry
                              you guys have never seen a gold 71 cap with the red caution label. years ago when I had my cap restored I could tell that it was gold at one time and it had the red label on it. it is in the 4600 range, could be early 71?
                                • 15601
                                #30
                                I am not aware of a gold cap with the red and white label, but I am open to learning. There is still a lot to learn about Corvettes.
