C2 Jack Compartment Cover - NCRS Discussion Boards
  • Randy S.
    • January 1, 2003
    • 586
    I am in the middle of a carpet install project. Is there a way to take the 1" bow or arch out of my jack cover. Is it not worth the trouble and just buy a repro.
    Randy
  • Gerard F.
    • June 30, 2004
    • 3806
    Re: C2 Jack Compartment Cover
    Randy.
    Had the same thing with my 67 jackboard.
    Put it on a concrete floor with wood wedges and blocks on the side you want to bend to. Then put heavy weights (like full paint cans on top) to put a little reverse bend in it. Leave it for a week or two, but check and adjust the weights once in a while. You could also wet or steam the inside of the bow in the bending process.
    It is worth the trouble, if you still have all your original tags and decals on the underside
    Jerry Fuccillo
    #42179
    Jerry Fuccillo
