Muncie tail stock mount bolts - NCRS Discussion Boards
  • Chuck R.
    • April 30, 1999
    • 1434
    I finally after a couple of months of inactivity have the power plant and tranny resting in the engine bay of my chassis. Man talk about getting the fire back in the belly!!
    What I'm missing are the two bolts that attach the tail stock mount to the crossmember plate.
    I'm guessing maybe a 7/16" grade five.
    Any input?
    Chuck
  • William V.
    • December 1, 1988
    • 399
    Re: Muncie tail stock mount bolts
    Chuck
    You are correct. 7/16 is what is needed and down the road should you want to replace the bolts with ones that has the correct head stamping, they are available from severl Corvette mail order parts houses and easly changes.
    • Chuck R.
      • April 30, 1999
      • 1434
      Re: Excellent Bill!
      Any idea on a length? I'll assume 1" would be safe without bottoming out.
      I'd like to scoop them up on the way home today rather than wait until tomorrow.
      Chuck
      • William V.
        • December 1, 1988
        • 399
        • William V.
          • December 1, 1988
          • 399
          Re: Excellent Bill!
          Chuck
          You only need two flat washers. Wow I almost had you buy two flat washers you don't need.
          BV
          • Chuck R.
            • April 30, 1999
            • 1434
            Re: Hmm.
            The kit must include the two additional bolts to secure the rubber mount to the tranny as well.
            Grade 8 huh? I'd have figured that the mount would shear off long before a grade five thought of giving it up.
            But hey, what's a grade or two extra between friends right?
            Thanks for the input Bill I appreciate it.
            Chuck
            • Chuck R.
              • April 30, 1999
              • 1434
              Re: What's a couple of washers
              Between friends
              Thanks again Bill,
              Chuckster
