C-3 body problem - NCRS Discussion Boards
C-3 body problem
  • Mark A.
    • February 1, 1996
    • 299
    C-3 body problem
    I am restoring a 69 coupe, big block non A/C car. The car was very rusty. Thers is considerable rust in the steel frame channel on the body, as well as the windshield frame and the birdcage itself. I decided to get a different body rather than attempt repair of this one. The body I purchased is for an A/C car. As I have learned, the opening for the heater core is larger on the A/C car, compared to the non A/C car. Question is, Has anyone ever grafted in the part of the cowl necessary to use the correct heater core on the A/C body? Is it possible to make in undetectable? Does anyone have a better idea on what to do? I would also be interested in trading my birdcage for a correct one, if someone has one. I would appreciate any help. Thanks, Mark
  • Chuck R.
    • April 30, 1999
    • 1434
    Re: C-3 body problem
    So I'm assuming that you plan to sacrifice a chunk of the "old" non A/C fire wall and graft it back onto the "new" A/C fire wall?
    I feel pretty confident in saying that a quality body man experienced in fiberglass and body fillers could perform the work and make the repair area vitually invisible to the human eye.
    Quality workmanship will cost you quality bucks Mark, as is always the case.
    Chuck
    • Harmon C.
      • August 31, 1994
      • 3228
      If you are changing the body why not just make the new car with A/C. Many manual steering cars now have power. Would be the same thing just more parts to find.
      Lyle
      Lyle
      • Yves Thaens
        Hi,
        There is much more to change than just the opening of the heater box. I don't think it is feasible. I would rather change over to a AC setup. If you really are anxious about original, I would still go the route of the birdcage repair. I have done a complete birdcage swap, it is difficult, but can be done.
        Yves
