1968 Body Mount / Cushion questions? - NCRS Discussion Boards
  • Steve Wallach
    The AIM for 1968 shows the same spacer as being used for Mount 4 and 3?
    On my 1968 Coupe, there was a two piece rubber mount in # 4, like my 67.
    I am fairly sure, the body had never been off before.
    What is correct? Also, the #1 mount only had an Aluminum spacer, washers, and shims. The frame mount has a large enough hole for the same type of rubber mount as #4, should it only have the Aluminum spacer, and shimms? That's what came off when I removed the body.
    Thanks for any input,
    Cheers,
    Steve
  • Greg L.
    • March 1, 2006
    • 2291
    Re: 1968 Body Mount / Cushion questions?
    Steve,
    My 69 had aluminum spacers on all 8 body mount locations and I'm pretty sure that is the way they were from 63 to around 75 or so.
    • Michael W.
      • April 1, 1997
      • 4290
      The first year for rubber cushions on C3s was 1973.
        • 43221
        Mike, et al-----
        Yes, 1968-72 Corvettes used the aluminum "puck" type mounts at all body mount positions.
        • Steve Wallach
          Thanks Joe and Mike,
          Was it common to replace these with out removing the body? Both my 67 and 68 have VERY OLD looking rubber bushings at the #4 mounts only.
          I'm now seeing in the catalogs that some offer different Aluminum pucks for different positions? For instance, Doc Rebuild's catalog shows the #1 RH and #4 LH to be a shouldered puck and the rest appear to be standard smooth pucks.
          What should be there? The Aluminum pucks removed from my 68 at 1 through 3 were pretty far gone, some dissintegrated to the point of being rocks of Aluminum Dust, so I don't really know what should go where?
          Thanks For any help on this,
          Steve
          • Steve Wallach
            Thanks Greg,
            Cheers,
            Steve
            • Joe M.
              • February 1, 2005
              • 590
              Early car mags had articles on replacing earlier aluminum mounts with the 'new' 1973 rubber mounts. Did this with my 69 and my bro-in-laws 68.
              Was just looking at that article yesterday.
              • Jim T.
                • March 1, 1993
                • 5351
                Steve if you decide to use the 73-82 rubber mounts the rubber mounts for coupes are all the same. For converitbles, mounts 1 and 4 are the same as the coupe, but mounts 2 and 3 are different from the coupe.
                • Steve Wallach
                  Hi Jim,
                  I intend to put the Aluminum Pucks back on my 68 Coupe.
                  Thanks Again,
                  Steve
                  • Joe M.
                    • February 1, 2005
                    • 590
                    Hope you can read this.....
                    can't get this larger as imageshack wants a small size to upload ...how can I set this up to easily be read?
                    • Steve Wallach
                      It appears the #1 LH and #4 LH mounts are "shouldered" Aluminum spacers or "Pucks".
                      I had a set I got off ebay some time ago, so I replaced these two and put a non shouldered spacer on the #4 RH.
                      I think that all should be "correct" now.
                      Thanks for all the help!
                      Now I may have to do it to my 67, which will be a bigger job since the body is on that car!
                      Steve
