Need Radiator Restored - NCRS Discussion Boards
  • Robert P.
    • November 1, 2004
    • 66
    Looking for someone that could restore a 71 LT1 radiator. Thanks for any help. Bob
    Re: Need Radiator Restored
    Most local radiator shops will do a decent job of repairing original brass radiators. Things to watch out when a local shop does the job and your objective is for a factory concours job include:]
    (1) Will he attach an 'ID' plate? Most shops want some way to identify their work for warranty purposes and will use a wire-on tag if you insist.
    (2) What color will they repaint it? Most use a FULL gloss black that's obviously brighter than factory original.
    (3) What do you want done about bent cooling fins? Most shops leave them 'as is' because it's a VERY tedious time consuming job to hand straighten the fins even with a fin straightening tool...
      • 11643
      and, most cores that a radiator shop would sell you are not 100% correct. DeWitts does sell the correct middle piece, but you have to use your original end tanks.
      Patrick
      • Robert P.
        • November 1, 2004
        • 66
        Thanks for the info. Called DeWitts,They have what I need and they are about 30 miles from me. Thanks again Bob
