C 3 Vacuum advance routing - NCRS Discussion Boards
  • Kevin G.
    • February 1, 2005
    • 1076
    Can someone post a picture of the correct installation of the vacuum advance line on a bb 71? It should be tight along the manifold the entire length correct? After about plug number 6, the rubber hose belongs on which side of the wire support? In the front the metal hose goes above or below the tube on the carb.? Thanks Kevin
  • Warren F.
    • December 1, 1987
    • 1516
    Re: C 3 Vacuum advance routing
    Kevin,
    If you have Dobbins 1968 to 1972 Stingray Fact Book, there are some good pictures of what you are asking for, on page 183. It is a good book to have for references. Unfortunately I do not have the ability to post pictures.
    • Kevin G.
      • February 1, 2005
      • 1076
      Warren, I do have the book, now where did I put it? Thanks for the tip! Kevin
