C1 air cleaner- hood clearance - NCRS Discussion Boards
  • daniel cavendish
    Seems most hoods on C1's (including my 62) have rubbing marks from the air cleaner and stud. Is this kosher? Thanks.
  • Mike E.
    • February 28, 1975
    • 5138
    Re: C1 air cleaner- hood clearance
    That usually means the rubber motor mounts are getting tired. I've not often seen the stud making a mark--usually see just the air cleaner. (and never seen a problem on a FI car)
    • daniel cavendish
      wouldn't "tired" motor mounts make the motor sit lower?
      • Robert S.
        • July 31, 2004
        • 377
        Not under acceleration especially from a dead stop :/
        Bob
        • Terry D.
          • May 31, 1987
          • 2692
          Daniel
          You did not specify but are you running the stock manifold and carb?
          • Terry T.
            • January 1, 2005
            • 13
            Daniel,
            Where is the rubbing occurring on your air cleaner? I posted a similar question a couple of months ago. I get some rubbing on the front edge of the air cleaner lid. I have the stock intake, correct carbs and what I think is an original aircleaner. My motor mounts ar less than a year old. I was told my one source that I must have the wrong aircleaner element because of the 1/8 inch gap between the top and bottom of the aircleaner, but in the phots I've seen, I think it's supposed to be this way.
            • daniel cavendish
              My car has been apart for so long now,I dont remember where exactly it's rubbing. Just saw a hood on ebay and saw the familiar marks. Back when I bought the car ,and knew nothing, I figured someone must have put a higher rise intake on. I've since learned that it's a correct manifold and carb. I had to use a bolt in place of the carb center stud to keep it fron hitting the hood. Will be interesting to see if new rubber mounts correct this. Thanks for the responses.
              • William C.
                • May 31, 1975
                • 6037
                Don't forget the aging of the front body mount below the rad core support to the frame under the Radiator. Age on this will allow the from to sag, changing the clearance of all the underhood items with relation to the frame mounted components such as the engine.
                Bill Clupper #618
                • Roy B.
                  • February 1, 1975
                  • 7044
                  1 wrong Carb base (car thicker)
                  2 soft front motor mounts
                  3 front radiator shims ( add more) worn!
                  4 trans rear mount soft
                  5 trans rear cross member shimmed to low lowing the trans rear are causing the engine front to rise to high.
                  6 hood not adjusted proper
                  This is a few things to think about!
