Cast iron PG ATF - NCRS Discussion Boards
Cast iron PG ATF
  • Michael L.
    • July 31, 2005
    • 562
    Cast iron PG ATF
    What transmission fluids are best to run in a cast iron Powerglide? Mine is a '55 model.
  • Roy B.
    • February 1, 1975
    • 7044
    Re: Cast iron PG ATF
    Any thing today is OK
    • Joel A.
      • September 30, 1997
      • 214
      Dextron would be best, but, as Roy said, anything would work. The older style Ford type "F" fluid will make it shift a bit firmer, but that's not really a good thing on an older ci/pg. I'd stick with the Dextron III.
      Joel Adams
      1974 Coupe
      1985 Coupe
      "I know the voices aren't real...but sometimes they have some really kewl ideas...."
      • Frank C.
        • January 1, 1986
        • 277
        IIRC...many many smelt seasons ago, I was told never to use F**d type "F" in GM tranny because it contained graphite
