67-82 Battery Clamps - NCRS Discussion Boards
    • 43221
    Recently, there was a discussion regarding C3 battery fitment. As a side issue, there was a little discussion about the battery clamps. Here's some information I didn't have time to post previously regarding the 1967 (without C-60) and all 68-82 battery clamps.
    The clamp used in PRODUCTION and available in SERVICE for 1967 (without C-60)and all 1968 through 1971 was GM #3887598. This clamp is of material thickness 0.065". It has 2 reinforcing "indentions" on the edge which articulates with the battery. The opposite edge has a very shallow "lip". The original example that I have is dip-painted semi-gloss black and I expect that this was a specification for the part.
    For 1972 through 1982 Corvettes, as well as SERVICE for 1967-71 Corvettes after January, 1973, the clamp used was GM #6270159. This clamp is similar to the above but differs in some easily discerned ways. First, it is thicker at 0.077". Second, the reinforcing "indentions" are gone (probably due to the thicker material). Last, the general configuration of the cross section of the piece is different with, especially, the rear edge having a much more pronounced "lip". This piece was black-phosphate finished, although I don't know if that was the exclusive finish used.
    There was also a SERVICE-only clamp (SERVICE-only for Corvettes but PRODUCTION for some other GM cars) used from the time the GM #3887588 was discontinued from SERVICE in January, 1970 until the GM #6270159 came along in January, 1973. That clamp was GM #1383273. It was a Buick piece which somehow found its way into use for Chevrolet SERVICE for a few years. I know nothing about it or why it was used for Chevrolet SERVICE.
    Below and following are a few comparative photos:
    • 43221
    Re: 67-82 Battery Clamps-Photo#2
    And another:
    • Chas C Henderson
      Joe,
      If you are having the problem of one's battery moving around, as in my 71, which of the clamps will work the best?
      Chasman
        • 43221
        Chasman-----
        Actually, from what I can deduce by studying the clamps' configuration, I think that either one should be equally functional. So, I would expect that if you have battery retention problems with one, you'll have it with the other, too.
        However, I think that I might give a slight nod to the 6270159. It's heavier gauge metal and, presumably, it was designed to accommodate later design batteries since it was used in PRODUCTION through 1982. Also, GM must have changed the part for a reason; they didn't change it because the 3887598 worked just as well. This MAY be a case where the later design part solved some problem experienced with the earlier design part.
        If your car still has the original clamp, then you should have the 3887598. So, you might want to try the 6270159. You can still get this piece from GM for a very nominal cost. So, it might be worth a try.
        • Chas C Henderson
          Thanks Joe, Ill buy one. *NM*
          • KEN BUTCHER
            GET IT AT THE WRECKER'S ALMOST FREE *NM*
              • 43221
              Correction
              The part number that I gave in the text of my response for the 67-71 clamp is incorrect. The part number seen in one of the photographs IS correct. So, the part number should be 3887588 and NOT 3887598.
                Joe -
                The 3887588 was also the PRODUCTION battery clamp for '67-'69 Camaros.
