69 brake shields - NCRS Discussion Boards
69 brake shields
  • A L.
    • January 1, 1992
    • 63
    69 brake shields
    Just curious what the judges look for on the 69 brake shields(backing plates). Thanks. AG
  • Chuck S.
    • April 1, 1992
    • 4668
    Re: 69 brake shields
    This has been discussed before, and the consensus was silver cad or zinc plating on the fronts, zinc galvanized or silver cad/zinc plating on the rears. I believe Joe Lucia said his original owner 69 had yellow dichromate on the fronts, but he it was the only one he had ever seen like that.
    Best bet for judging is to forget the yellow dichromate (correct for later cars) and go with zinc plating on both fronts and rears.
    • A L.
      • January 1, 1992
      • 63
      Chuck, do you know if part numbers ect, are judged? Would silver cad repros with part numbers pass muster? My original 69's are not in very good shape and am trying to figure out how to deal with this item.
      AG
      • Chuck S.
        • April 1, 1992
        • 4668
        Assume that judges will look for the presence of the part number. Several years back there were repro shields without the part number...those repros may still be out there, and that would cause judges to look for imposters without part numbers.
        If your shields only need refinishing, that would be the course I would take; zinc plating is not that hard to find. If they are so deformed or rusted as to require replacement, check out the shields offered by Bair's Corvette...they sold NOS as long as they had them, and then offered what is described (I haven't examined them) as very good repro with part numbers. I don't think anyone still has NOS, but I could be wrong.
