C-2 green lens? - NCRS Discussion Boards
C-2 green lens?
  • Dale S.
    • November 12, 2007
    • 1224
    C-2 green lens?
    I was taking my shifter console out of my 67 coupe and found a thin green plastic cover that looks like it might go over a light bulb. It was on the left side of the console, under the screw mounting bracket. Can somepne tell me where it goes? Thank you dale
  • Donald O.
    • May 31, 1990
    • 1591
    Re: C-2 green lens?
    That is for the heaqter/fan and radio controls. It is to give them a pretty green tint.
    • Dale S.
      • November 12, 2007
      • 1224
      Re: C-2 green lens?
      Where is it located? Thank you Dale
      • Donald O.
        • May 31, 1990
        • 1591
        Re: C-2 green lens?
        Clips to the dash panel at the bottom of where the clock gets installed and gets its ground from the case of the clock when the clock is installed.
        Don
          Re: C-2 green lens?
          It goes over the end of the "torpedo" lamp that clips to the clock retainer at 6 o'clock (A/C cars have two more, at 4 and 8 o'clock. Lamp in the photo is shown without the green hood.
          • Dale S.
            • November 12, 2007
            • 1224
            Re: C-2 green lens?
            Ok John, It would be missing on one of the two lights as it has A/C. What holds them on? Thank you for your help. Dale
            • Mike Barnard Sr No 36249
              Re: C-2 green lens?
              It just stretch's over the end like a rubber glove. Just make sure it cover's the square hole in the shield.
