Dash Paint - NCRS Discussion Boards
Dash Paint
  • Mike Barnard Sr No 36249
    Dash Paint
    Can anyone tell me the correct paint brand and No. for the 65 Black on the dash. I am trying to refinish the speaker grill and have tried different shades and brands with no luck.
  • Bryan L.
    • June 30, 1998
    • 397
    Re: Dash Paint
    Try SEMS Trim Black, it is available at most auto paint stores. Some guys like Krylon 1613 but I'm partial to the SEMS product.
    BL
      Re: Dash Paint
      Thanks Bryan. What shade of black have you found match's the best.( satin, semi-gloss etc.)
      • Joseph T.
        • March 1, 1986
        • 169
        Re: Dash Paint
        Mike.
        Krylon Semi Flat Black in the rattle-can will be a perfect match. I have used it on several occasions with excellent results.Good Luck.
        • Bryan L.
          • June 30, 1998
          • 397
          Re: Dash Paint
          The SEMS part # is 39143. The Krylon 1613 is a bit cheaper and probably easier to find if you're not close to a paint store.
          HTH
          Bryan
            Re: Dash Paint
            Thanks Joseph:
            I know where I can get some Krylon. I'll give it a try.
              Re: Dash Paint
              Thanks again Bryan.
              • Gerard F.
                • June 30, 2004
                • 3806
                Re: Dash Paint
                Mark,
                I like the Krylon 1613 semi flat, you can get it at Walmart. However it is very thin stuff and don't expect it to fill imperfections in the area you are painting. Sand the area very smooth, and the paint will come out very smooth with multiple light coats.
                I used it on my Glove Box project.
                Jerry Fuccillo
                #42179
                Jerry Fuccillo
                  Re: Dash Paint
                  Thanks for the info Jerry. My main concern is matching the paint on the rest of the dash as I don't want to remove the whole assembly and repaint.
                  • Bryan L.
                    • June 30, 1998
                    • 397
                    Re: Dash Paint
                    I mistakenly referred to a paint manufacturer as SEMS and it is actually SEM. I guess I got it confused with a bolt head marking and the name of a road where I live.
                    BL
                      Re: Dash Paint
                      No problem Bryan.
                        Re: Dash Paint
                        Bryan & Jerry
                        Thanks for the help. I ordered a can of each from my local NAPA today. Will try each this weekend to see which match's the best.
