changing a Hurst shifter - NCRS Discussion Boards
  • Dale S.
    • November 12, 2007
    • 1224
    Can any one give me a easier way to change a Hurst to a stock shifter? Notice I said easier not easy. Looks like the exhaust has to come down. Any help would be appreciated. Dale
  • Mike M.
    • September 30, 1999
    • 710
    Re: changing a Hurst shifter
    When I changed mine on my 65, I lowered the trany by taking the mount out and the exhaust bracket and letting the trany rest on the crossmember. It gave me a little more room to get at the bolt to remove the shifter. It takes a while to get the bolt out because you can only turn it about a 1/8 of a turn each time you put the wrench on it. The stock shifter goes in easy. A latter year corvette might be different because some shifters were not mounted on the transmission. Mike
    • Mike M.
      • 710
      One other thing
      I removed the the shielding and the distrubtor cap as it gets close to the firewall .
      • Terry D.
        • May 31, 1987
        • 2691
        What Year are You Working On? *NM*
        • Dale S.
          • November 12, 2007
          • 1224
          Re: What Year are You Working On?
          Sorry Terry, 1967 coupe,300 HP,4 sp,under car exhaust,C-60,K-19. Thank you Dale
          • Mike M.
            • May 31, 1974
            • 8385
            snap-on has a 1/4"drive swivel socket that will get in there and do the job. you'll need extensions about 18" in length also. mike
            • Dale S.
              • November 12, 2007
              • 1224
              Thanks guys, Guess I will venture tomorrow. Dale
