Any way to take this washer plunger apart? - NCRS Discussion Boards
  • Greg L.
    • March 1, 2006
    • 2291
    As the subject says, is there some way to take this apart to replace the seal? If not are they available new or is saturday going to be junkyard day for me?
    Greg Linton
    #45455
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: Any way to take this washer plunger apart?
    Greg
    I belive that is the type you push the plunger down and turn 1/4 turn to remove.
    Lyle
    Lyle
    • Greg L.
      • March 1, 2006
      • 2291
      Thanks Lyle...worked like a charm!
      • Jeffrey S.
        • May 31, 1988
        • 1882
        Greg:
        The seal is not, to my knowledge, replaceable. I can be made to seal by putting an o-ring under the seal. This forces the seal against the wall of the cylinder and returns the unit to proper operation. I have been successful in doing this on several different pumps. Hope this helps.
        Jeff
        • Myron Sleeva
          Have been able to accomplish a temporary ( which turned into a permanent) renewed seal by using a couple of laps of teflon tape under an o-ring or rubber seal. Easily adjustable.
          • Greg L.
            • March 1, 2006
            • 2291
            Your right Jeff in that for all intent purposes that seal is not meant to be replaced...I did manage to change it with a good one but it was a bear to say the least. I would have just swaped plungers but I busted the one with the better seal taking it apart.
            Anyways I went to the wrecker today and picked up a bunch of pumps so out of all of them I should be able a good working unit. If not, I'll try yours and Myron's suggestions.
            Thanks again
