Antenna Mast - NCRS Discussion Boards
Antenna Mast
  • Douglas L.
    • August 31, 2003
    • 299
    Antenna Mast
    This is amazing!!
  • Robert S.
    • July 31, 2004
    • 377
    Re: Antenna Mast *NM*
    Try this Link
    Bob
    • Douglas L.
      • August 31, 2003
      • 299
      Re: Antenna Mast
      Let's see if this link will work better:
      • Terry D.
        • May 31, 1987
        • 2691
        A Fool and His Money Will Soon Be Departed! *NM*
        • William C.
          • May 31, 1975
          • 6037
          Listing removed by eBay *NM*
          Bill Clupper #618
          • william e snyder
            Re: Listing removed by eBay
            gm used the same mast on the chevy p/u as well as other carsi must have a few around i should list them
            • Douglas L.
              • August 31, 2003
              • 299
              Bill,
              $ 305.00 for a 67 Antenna mast! Hard to believe. If you copy and paste the address, it will still come up. I don't know why the entire address wouldn't post.
                • 11643
                No, it's there
                As Doug says, the link fragments and then doesn't lead you to the correct page.
                Take the Item Number from the end of the link, and paste in into ebay. You'll find it.
                Patrick
                • Charles K.
                  • May 31, 2006
                  • 90
                  Re: No, it's there
                  I cant say much I spent $150 for a NOS antennae and lead wire for my 64.
                  • Harmon C.
                    • August 31, 1994
                    • 3228
                    I found the item
                    It's time to start digging in the garage again.
                    Lyle
                    Lyle
                    • Bryan K. Montford
                      Re: Antenna Mast
                      I better keep a close eye on my 68 mast. You never know when a shifty 67 owner might be lurking around
                      Bryan
