1965-6 PB Master Cyl...."eVilmay" 160076528818 - NCRS Discussion Boards
  • Dan A.
    • May 31, 1974
    • 1074
    I would like to know what others thoughts are of the master cylinder at auction on "eVilmay". Auction number is 160076528818.
  • Rob A.
    • December 1, 1991
    • 2126
    Re: 1965-6 PB Master Cyl...."eVilmay" 160076528818
    Dan,
    I compared it to one I have(6467084). The only difference that stands out is that mine has additional markings on the side where the lines attach, about even with the rear cap....a couple of numbers with slotted screw impressions on both sides. Also the original caps on mine are not so clear. I believe even when new, they were not as clear as the ones in the Ebay listing.
    • Rob A.
      • December 1, 1991
      • 2126
      I'm guessing the absence of the numbers I mentioned(maybe a shift marking) that are present on mine would indicate this was a service replacement...which if it is, woudn't mean it isn't very rare and evidentally valuable.
      • Dan A.
        • May 31, 1974
        • 1074
        • Dan A.
          • May 31, 1974
          • 1074
