Crossmember Dent Removal Tool..... - NCRS Discussion Boards
  • Terry F.
    • September 30, 1992
    • 2061
    Hi everyone. As some may know I produce the tool used to remove the dent in the underside of the front crossmember. Recently it was brought to my attention that someone had problems with the press-plate fitment inside the crossmember. The tool was designed to fit loosely in the crossmember cavity of 1963 to 1982 corvette. If anyone that has used the tool has experienced similar difficulty, I would appreciate hearing from you. Best regards, Terry tfringo@aol.com
  • William C.
    • May 31, 1975
    • 6037
    Re: Crossmember Dent Removal Tool.....
    Worked Great for me Terry, I think we sold several of them for you while judging cars down in Fla last week!
    Bill Clupper #618
    • Terry F.
      • 2061
      That is a relief to know. I put a lot of work into the tool but I think there are variations in front crossmembers that I might find difficult to account for with the tool as it is built. I have sold nearly 100 of these tools and twice I have received feedback (one very recently) that the tool was too tight to fit the crossmember. That individual cut a 1/4 inch off the leading edge and was able to make the tool fit properly. But, I honestly did not intend for people to have to make such adjustments. Regardless, it still worked for that individual. Thank you for the feedback. Best regards, Terry
      • Kent K.
        • December 1, 1982
        • 1139
        Terry - While my '67 was on the rack at Old Town for the advanced judging seminar, Bill Clupper and others spoke about your front crossmember dent removal tool and how easily dents are worked to disappear like they were never there. They sold me on it if the need arrises.
        Regards, Kent #6201
        Kent
        NCM Founder - Member #718
        • Mike M.
          • September 30, 1999
          • 710
          Terry it worked great for me. Mike
          • Terry F.
            • 2061
            It is all good to hear. I just didn't know if I needed to get into panic mode??I hope more people respond. I will be contacting others directly to find out if there is a trend in the later C3's that make it fit differently. Thank you, Terry
            • Eric J.
              • March 1, 1980
              • 771
              Why is the dent there?
              Terry/All, My 78 has a dented front cross memeber and I always wondered why. In general what caused it? Curbs? Eric #3,182
              • Terry F.
                • 2061
                Re: Why is the dent there?
                Eric,
                It looks like it would be a great place to lift the car from but actually it is not intended as a lift point. I straddle the whole crossmember with a strong block of wood when lifting from that point. But, if you stick a floor jack or bottle jack in that center section, you will soon cave that center section in. Regards, Terry
                • Eric J.
                  • March 1, 1980
                  • 771
                  Terry, Thank you for the response, I have never thought to lift the car there. Looking at the dent on my 78 it makes sense now. Much like never lifting using the steering/rad support bracket on a solid axle. Hope your tool works.
                  Eric
                  • Terry F.
                    • 2061
                    Thanks, Terry *NM*
                    • Phil P.
                      • April 1, 2006
                      • 409
                      Re: Thanks, Terry
                      great tool---used it last year and then i called you to say how great it was---also asked when you will be making a tool for first year camaro???thanks,phil
                      • Terry F.
                        • 2061
                        Re: Thanks, Terry
                        Thanks for the feedback. Show me where I can find a section of the crossmember and I will make one. Terry
                        • Dennis H.
                          • September 30, 2005
                          • 226
                          Great Feedback on this tool, I have been tracking it on ebay for several months. Just ordered one as my 65 frame looks like dog lips.
                          • Terry F.
                            • 2061
                            I will have to look at a dog now to see what you are talking about. Maybe if I made a smaller version I could offer my services/tool for dog owners??? Just a thought. Thanks, Terry
                            • Terry F.
                              • 2061
                              Thanks! Terry *NM*
