Question for Dick Whittington - NCRS Discussion Boards
  • Stephen B.
    • April 1, 1988
    • 876
    Dick,
    As you were gleefully marking off points on the Mechanical of my poor 'ole '70 (just kidding), you said that I had an incorrect air cleaner wing nut. You stated that it was too thick. I have found what I believe is the original wing nut. What do you think?
  • Stephen B.
    • April 1, 1988
    • 876
    Another picture *NM*
    • Kevin M.
      • November 1, 2000
      • 1271
      Re: Question for Dick Whittington
      Don't know 70's but the thickness is right, the repo looks like the size on my 67 but it as thin as your small one.
      Kevin
      • Dick W.
        • 10483
        Remember what I said about the "nickle and dime"? The replacement is as thick as a nickle. The original are the thickness of a dime
        Dick Whittington
        • Dick W.
          • 10483
          I meant to add that I do not know if the angle of the picture makes the difference or what, but the original wing nuts are approximately the same size as the repro.
          Dick Whittington
            • 43222
            Stephen-----
            Depicted below is an absolutely guaranteed, known-original nut from 1969. 1970 used exactly the same nut.
              • 43222
              Addendum
              By the way, the material thickness on the original wing nut is right at 0.0675"
              • Harmon C.
                • August 31, 1994
                • 3228
                Re: Addendum
                Hey Joe how thick is a dime and a nickel? I can't find my 1" Mikes.
                Lyle
                Lyle
                  • 43222
                  Re: Addendum
                  Terry----
                  A dime is, nominally, 0.052" thick. A nickel is 0.074".
