Fastener orientation - NCRS Discussion Boards
  • Don Y.
    • July 31, 2000
    • 166
    I have a question regarding the correct orientation of fasteners on the frame of my car. I am preparing to disassemble the frame and I note there are some unusual bolt orientations. The front frame member is retained by 16 bolts. The front group has the threads pointed up and the rear group has the threadss pointed down. The AIM shows all bolt orientations in the same direction. The car is a late '57 and has two rear axle bumpers. The bolts on the front bumper are pointed up but the rear ones are pointed down, the AIM shows the orientation of both sets of bumper bolts the same. When reassembling should I put them the way they came out or the way the AIM shows? I am fairly certain these fasteners have never been disturbed.
  • Joe M.
    • February 1, 2005
    • 590
    Re: Fastener orientation
    Took a quick look at my two vettes......
    61 vette - 8 inboard bolts and 4 rear R/L outboard bolts are all washer and nut topside. the 4 front R/L outboard bolts have the nut and washer on the bottom.
    57 vette - all bolts have the nut and washer on the bottomside.
    • Chris H.
      • April 30, 1990
      • 817
      My fasteners that held the front crossmember to the frame were not all in one direction. I will post photos later.
      Chris
      • Chris H.
        • April 30, 1990
        • 817
        Here are photos of the fasteners. Far as I can tell they are original. (can you believe that some even broke as I removed them:) )
        Let us know if yours were in the same orientation as mine. If not it was probably a random installation.
        I can still not believe how bad it was under there and how nice it looks now! Of course I had a little help.
        User/password is chenige / chenige
          I recall a paragraph in the book Dale Pearman prepared for our joint presentation at the Bloomington Gold Restoration Workshops in 2002 on '58-'62 Chassis Assembly that the four inboard crossmember bolts on each side were installed with the heads facing the ground and the outboard four on each side were installed with the nuts and washers facing the ground in order to avoid interference between the inboard bolts and the bumper brackets.
          • daniel cavendish
            If anyone get's a final word on this one, please post it. I am at this stage also. Thanks
            • Don Y.
              • July 31, 2000
              • 166
              Dan,
              What did you paint your front crossmember with?
              • daniel cavendish
                Krylon semi- gloss, don't know if correct or not. I'm not too far that I can't paint over. Do you know if the bolts went up or down?
                • daniel cavendish
                  sorry, just realized yours was the first post!
