63-72 #3155316 Radiator Question - NCRS Discussion Boards
  • Glenn Rogers
    I ran across a 3155316 radiator with a yr 77 date stamp and was curious if that could be right?
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: 63-72 #3155316 Radiator Question
    Service replacement. I have a 62 model with an 81 date code.
      • 43221
      Glenn-----
      It's just as Wayne stated. However, if you find one with a 1986 or later stamp, then that will be a real curiosity. Harrison ceased the manufacture of this radiator prior to that time. I don't think that Tom DeWitt would put any date on his reproduction radiators after 1972 since that was the last year for PRODUCTION use of this unit.
      • Glenn Rogers
        3155316 Dated 77: Impact on Value?
        Especially on an otherwise original numbers matching 63-67?
          • 43221
          Re: 3155316 Dated 77: Impact on Value?
          Glenn------
          Well, it's obviously an incorrectly dated unit for any original application. So, I would presume that would have some affect on value. However, on this issue, original Harrison radiator practices give one a "solution". Many original 3155316 radiators have a small plate welded to the top of the radiator and the date code is stamped into it. So, presumably, one could add such a plate over the incorrect date, stamp it with the appropriate date, and all would be well.
