What is the best way to remove water spots from the glass T-tops?
Water spots, please leave!
Tags: None
- Top
Re: Water spots, please leave!
If CLR does not work (doesn't work onall minerals) try some alcohol and razor blade (careful) or the vinagar solution (that can also be used on paint to do the same) or some Clean Shower (by Arm & Hammer)which works for me where CLR does not (different minerals).
Good Luck and post results.
Alan- Top
I have found clay -- the same as used on the paint finish -- removes water spots. The spots are different depending on the minerals in the water, so try various methods until you find one that works.Terry- Top
