ignition wiring harness on 65 with 327 - NCRS Discussion Boards
  • tim colleran
    I am in the process of restoring a 65 small block, that at one point was modified to be more like a 67 clone, back to original condition. I just changed out the wiring harness and the car no longer starts. Can anyone recommend a source for a step by step debug of harness problems?
  • Mike McKown
    Re: ignition wiring harness on 65 with 327
    Doesn't crank over? No fire at the coil? What?
    • Randy S.
      • January 1, 2003
      • 586
      Tim,
      If you bought the harnesss from Lectric Limited they are supposed to offer free technical support. I would like to know if they are any good.
      I would start with checking your grounds
      Randy
      • tim colleran
        It does not crank, Heater blower fires up and horn works, but trying to turn it over just is a deafening silence
        • Timothy B.
          • April 30, 1983
          • 5186
          Tim,
          Get under the car with a test light, have someone turn the ignition key to the crank position and see if there is power on the S terminal at the starter solenoid. Make sure the car is in neutral with emergency brake on and wheels chocked. If you have power at this terminal there is a problem at the solenoid, if no power then it's from the wire back to the ignition switch and you will have to start process of elimination.
          • Scott S.
            • February 1, 2002
            • 62
            I too had a problem w/my 65 harness that I purchased new from LL. The pins were screwed up when I got it & didn't realize this. I further destroyed them by forcing onto the fuse block. Ended up costing me 104.00 to buy a kit from LL w/all new pins & block. Make sure all the pins on the firewall mate up correctly and don't force it unless you want to screw around & pay also!
