Electrical Question For 66 327/350 - NCRS Discussion Boards
  • J M.
    • July 31, 2005
    • 60
    This morning I hooked up the electric choke on my replacement Holley. I wanted to check the current readings and this is what I found. Choke hooked up to bottom of ballast resistor reads 11 VDC. Top of ballast resistor reads 5.22 VDC. Battery reads 12.2 VDC. Are these readings normal? 5.22 does not seem like enough coming out of ballast resistor. Any help appreciated.
  • Albert P.
    • April 1, 2006
    • 205
    Re: Electrical Question For 66 327/350
    The choke heater has to be connected to the high side or battery side of the ballast resistor.
