Roy Braatz or ?? re 1955 decals - NCRS Discussion Boards
  • Don S.
    • February 1, 2000
    • 476
    Getting ready for flight judging of 55 vette.
    Need to know where the jacking instructions get pasted or glued or stapled. . Is it on the top side or the underside of the spare tire plywood cover and does it matter where it is located on the proper side.
    Also need location to stick the convertable top instructions.
    Also need to know the location to attach the ncrs window decal round sticker.
    Thanks in advance guys.
  • Mike M.
    • May 31, 1974
    • 8391
    Re: Roy Braatz or ?? re 1955 decals
    jacking instrctions glued to topside of board, usually about 2 oclock. conv top label sewn to lower left edge of rear window opening on exterior of top material. ncrs decal can go anywhere on the front windshield but don't cover the LOF logo. mike
    • Kevin M.
      • November 1, 2000
      • 1271
      I thought you could put the NCRS decal on any window you wanted too. I had the decal on my back window where the date was supposed to be, wasn't a problem when judged. Don't forget a cut off switch and a small unmonted fire extinguisher for even more points.
      Kevin
      • Mike M.
        • May 31, 1974
        • 8391
        you are correct in that the ncrs decal can go on any windows but i'd be reluctant to put it on a plexiglass side curtain or rear plastic window. tough to remove later from these materails.mike
        • Roy B.
          • February 1, 1975
          • 7044
          Mike covered the rest , this is original for the soft top instruction, NCRS sticker any where on the WS L/S is good
          • Dennis C.
            NCRS Past Judging Chairman
            • January 1, 1984
            • 2409
            Mikie usually has NCRS sticker on forehead... *NM*
            • Mike M.
              • May 31, 1974
              • 8391
              Re: Mikie usually has NCRS sticker on forehead...
              "and yer flag decal won't get you into heaven anymore" . John Prine @ 1964.one of my favorite tunes---ranks right up there with comander cody and "momma hated diesels so bad".we'll be spinnin both at the MAC 25th anniv meet at the farm labor day 2007. plan on attending. mikie
