C-1 '61 Door Hinges - NCRS Discussion Boards
C-1 '61 Door Hinges
  • Richard P.
    • May 31, 2002
    • 190
    C-1 '61 Door Hinges
    Are all 4 door hinges (top & bottom & left & right) identical on a 61? Thanks.
  • Mike E.
    • February 28, 1975
    • 5139
    Re: C-1 '61 Door Hinges
    No--there are two rights and two lefts.
    The difference? Each hing has a metal plate riveted to it to
    "catch" the door and keep it from swinging back shut without you wanting it to.
    That riveted piece is on the top of the arm--so when you put all four with that piece on the top, the four suddenly orient themselves into two lefts and two rights. Otherwise, no difference.
    • Richard P.
      • May 31, 2002
      • 190
      Mike Ernst Re: C-1 '61 Door Hinges
      Mike,
      My door hinges each have 2 catches. One on top and one on bottom. The catches have "M PAT NO 2342531" stamped on them. the rivets each have either "D" or "C" or "N" stamped on the head. My car is a Feb. '61 built car. Is this a running change or do I have the wrong hinges? (very possible) Thanks for your help.
      Richard
