EX MANIFOLDS, EX SYSTEM - NCRS Discussion Boards
  • Mike M.
    • April 1, 2007
    • 60
    I HAVE A 1962, 300 HP, POWERGLIDE I'M TRYING TO FIGURE OUT WHAT EXHAUST MANIFOLDS WERE USED ON THIS APPLICATION, THE NCRS BOOK SAYS CAST# 901 FOR LH & 902 FOR RH, I HAVE ALSO RESEARCHED IN THE CHEVY PARTS BOOKS THEY ALSO COME UP WITH THESE NUMBERS EXCEPT FOR POWERGLIDE, SHOULD THEY BE CAST# 965 FOR LH & 556 FOR RH THESE ARE THE 250 HP MANIFOLDS IS THIS CORRECT, AND IS IT BECAUSE IT IS A POWERGLIDE? ALSO DID THIS APPLICATION USE A CROSSOVER PIPE & WAS IT 2" OR 21/2". I DON'T CARE WHAT SET UP IS USED I JUST WANT IT CORRECT.
    THANK YOU FOR YOUR HELP.
  • Mike E.
    • February 28, 1975
    • 5139
    Re: EX MANIFOLDS, EX SYSTEM
    Mick--
    Please turn off the caps--that's shouting, and we prefer that people don't shout.
    62 300HP cars had 901 and 902 manifolds. I've owned two of them, and they were both original cars.
    • Mike M.
      • April 1, 2007
      • 60
      turned off the caps, sorry didn't know that.
      were your cars powerglides & did they have crossover pipes?
      thanks
      • Terry R.
        • March 1, 2005
        • 359
        Mick I have a '62,300 hp,powerglide car also. I took my original manifolds off because of excessive pitting(not really that bad)installed GM replacements with same part # but different casting characteristics, cost me four points for the education at San Antonio.My car has crossover pipe and 2 1/2" pipes. Good luck.
        • Mike E.
          • February 28, 1975
          • 5139
          Yes, and yes. I should have mentioned those two were powerglide--I've had 28 62's in all. 300HP cars used crossovers--that's the way they were built--no optional engine in 62 was without crossover.
            • 43242
            Mick-----
            I agree with Mike and Terry; a 1962 300 hp engine, with or without Powerglide, used the GM casting #3797901 and 3797902 exhaust manifolds. These are 2-1/2" outlet manifolds.
            What generates the confusion here is that things changed for 1963-65. For 63-65, the 300 hp (L75) engine with manual transmission used the same manifolds as described above. However, for 300 hp (L-75) engine with Powerglide used different manifolds with 2" outlet size.
