Ball joint rivets - NCRS Discussion Boards
Ball joint rivets
  • robert erb
    Ball joint rivets
    Can anyone point me in the direction of a good procedure to install new correct ball joint rivets (both upper and lower), I know where to get them but not how to properly install them. Any help would be greatly apprecited.
  • Greg L.
    • March 1, 2006
    • 2291
    Re: Ball joint rivets
    Robert,
    The best advice I can give you right now is to search the archives for ball joint rivets with my name in the search title. I just went through what you are about to so you will probably find the info that you need there.
    If you have any further questions though after your search feel free to ask.
      • 43242
      robert-----
      Special tooling is required to install the rivets. In general, the acquisition of such tooling is not off-set by the cost of just having someone with the tooling and experience do it for you. Unless, of course, you plan to do a LOT of these. However, if you're like most folks who will only do this once or twice in your life, it's much more cost effective to send them out. Among others, Bair's in Lineville, PA and Van Steel in Clearwater, FL can perform this task for you.
      • Rob A.
        • December 1, 1991
        • 2126
        If you happen to live in S. California....I can direct you to someone who has a press set up to do it.
        • William C.
          • May 31, 1975
          • 6037
          I took the easy way out and sent mine to Bairs, they have the tooling and do a LOT of them so the guy who does it gets a lot of practice.
          Bill Clupper #618
          • Tracy C.
            • July 31, 2003
            • 2739
            Where did you find the rivets?
            • Harmon C.
              • August 31, 1994
              • 3228
              Volunteer Vet in Knoxville had them the last time I needed some.
              Lyle
