Looking for 1970 LT-1 Block - NCRS Discussion Boards
  • Stephen B.
    • April 1, 1988
    • 876
    My car is #5020 and dated February 26, 1970. The broadcast code needed is CTU. Thanks, Bunky
  • Gary Schisler
    Re: Looking for 1970 LT-1 Block
    Have you tried The Restorer or Hemmings?
      Your odds will be far better to just look for a 3970010 block with a casting date that fits your 6-month "window"; they made about seven million of them. Most of the block points are for the casting number and date anyway.
      • Stephen B.
        • April 1, 1988
        • 876
        You're probably right; however, the chase is a lot of fun. I'll probably pick-up an 010 block while I look for the CTU. I've seen complete LT-1 engines for sale over the years. Thanks, Bunky
        • Stephen B.
          • April 1, 1988
          • 876
          I'm currently looking through both. The chase is a lot of the fun. Thanks, Bunky
          • Gregory G.
            • August 31, 2004
            • 107
            Get the right casting, date and restamp!
            If you have an original documented LT-1 why not get the proper casting number and date and restamp the block with the proper suffix and vin number. From reading this board it is my understanding that if the car was originally equiped that way there is nothing wrong with this practice. You are only restoring the car back to the way it appeared originally. You can always tell any future buyer that this was done. You could also post this to the LT-1 registry so the future buyer can not later say it was the original block.
            I am sure that there will be a lot of different openions on this subject.
            • Rick S.
              • January 1, 2003
              • 1203
              Re: Get the right casting, date and restamp!
              Greg,
              I'm would think your comment about getting a lot of different opinions on re-stamping a block will generate many comments.
