'62 rear bumper bolts - NCRS Discussion Boards
  • Terry R.
    • March 1, 2005
    • 359
    Does anyone have a picture of the vertical bolts that hold the center rear bumper on? The bolt ends are seen in the trunk,I've seen them before but didn't take notes. Can't find any originals or reproduction. Thanks
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: '62 rear bumper bolts
    No pics, but WB head marking as I recall.
    • Mike E.
      • February 28, 1975
      • 5138
      I checked the 4 62's I have that have under 65k miles. Those bolts on two of them are WB pattern, 1 has WB1C and the other has no ID on the head at all. All are pointed bolts, and all are cad plated many, many years ago. Hope that helps.
      • Terry R.
        • March 1, 2005
        • 359
        The reproduction bolt kits come with the right head marking but not pointed on the end. Is the point sharp like a pencil or kind of depressed like a shoulder to help with lining up? Thanks for the help.
        • Mike E.
          • February 28, 1975
          • 5138
          Not as sharp as a pencil, but fairly close. Definitely was for easy starting in a spot that wouldn't always easily line up.
          • Terry R.
            • March 1, 2005
            • 359
            Thanks Mike,I knew you would come through with the correct info! Terry Robertson
