C1 Brake Drums - NCRS Discussion Boards
C1 Brake Drums
  • Art B.
    • 333
    C1 Brake Drums
    I pulled the drums on my '61 and will have them turned. While I have them out I would like to put some finish on them not only for appearance but also for preservation. In the archives, I noted unpainted, semi-gloss black and gloss black all stated as correct. Which is it? I see that Eastwood sells a Brake Drum Coating that can be sprayed right over bare metal. Have any of you used this product?
  • Peter K.
    • January 1, 1999
    • 117
    Re: C1 Brake Drums
    They came from the factory un-painted, I have sprayed mine with cast iron grey to preserve them and it has worked well both in judging and for preservation
    • Terry D.
      • May 31, 1987
      • 2691
      Re: C1 Brake Drums
      Art
      I have used the Eastwood product for brake drums and it worked quite well. As with any other paint job make sure drums are really clean before applying their product.
      • Michael H.
        • January 29, 2008
        • 7477
        Re: C1 Brake Drums
        Art,
        I'm far from a C1 expert but I'm pretty sure your drums were originally coated with chassis black, a semi gloss/flat gooey coating. Most semi gloss/flat paints will give aprox the same apperance.
        Most of the entire spindle/knuckle, backing plate and drum would have been coated in this way.
        • Rob M.
          NCRS IT Developer
          • January 1, 2004
          • 12740
          Re: C1 Brake Drums
          Maybe this picture of an original 61 dismantled in 62 will provide some answers:
          http://www.c1registry.com/index.php?...e=14&art_id=-2
          greetings,
          Rob.
          Rob.
          NCRS Software Developer
