66 options - NCRS Discussion Boards
66 options
  • Les Veach
    66 options
    which of the below options could have been on a (rally red/black)
    66 roadster 327/300 with trim tag TRIM STD ?
    A01 Tinted windows
    A31 Power windows
    A82 headrests
    C07 Folding Top Color
    F40 Special Front & Rear Suspension
    G81 Positraction Rear Axle 3.36 ?
    J50 Power Brakes
    N14 Side mount exhaust
    N32 Teakwood steering
    N40 Power steering
    T01 Goldwall Nylon 7.75 x 15
    U69 AM/FM Radio
    V74 Hazard Warning Switch
    • 43221
    Re: 66 options
    Les-----
    Except for F-41 (F-40 was last used for the 1965 model year), any of the options listed could have been ordered for the car you described.
    • Wayne M.
      • March 1, 1980
      • 6414
      C07 is hardtop (w or w/o softop)
      ... which you could have had as well. C05 is softop w/beige or white (in place of black), although the code C05 did not appear on the dealer order form.
      Too bad your interior was not of another color than black, AND if your body was produced at St.Louis, there would be a suffix code following the trim color code that would tell you the body options.
        Re: 66 options
        Your other post over on CF that had the trim tag info shows it's an A.O. Smith body, so it wouldn't have had the factory N14 sidepipes.
