Merry Christmas and a '64 temp gauge problem - NCRS Discussion Boards
  • Joep F.
    • March 1, 2006
    • 40
  • Joe R.
    • July 31, 1976
    • 4551
    Re: Merry Christmas and a '64 temp gauge problem
    Joep,
    Does the pointer peg to the right with the green wire going to the sending unit in the manifold disconected?
    The temp gauge needs to be grounded thru the bottom mounting stud that comes thru the back of the temp gauge. There are two mounting studs and the bottom one must be grounded.
    Make sure you haven't blown a fuse on the panel to the left of the steering column.
    Gently tighten the two screws on the back that mount the connecting lugs to the gauge back.
    If none of this gives any results you should send the gauge back to the instrument company that took your money.
    JR
    • Joep F.
      • March 1, 2006
      • 40
      Thanks, the gauge wasnt properly grounded. It works ok now.
