'63-'64 bumper front bumper arms - NCRS Discussion Boards
  • Mike McKown
    There is a thickness difference in '63-'64 front bumper arms. I have some parts that measure about .175 and some that measure about .250 thickness. Myself and several others have forgotten the story here. What's the scoop?
  • Michael H.
    • January 29, 2008
    • 7477
    Re: '63-'64 bumper front bumper arms
    That's correct Mike. The fat brackets/braces were 63 and the thin ones 64.
    • Mike McKown
      Uhhhhhh, guess it'd be too much to ask if this
      is in the judging guide? Do you know anything about a "D" stamp on the arms?
      Thanks.
      PS. The next question is a little harder.
      • Michael H.
        • January 29, 2008
        • 7477
        Re: Uhhhhhh, guess it'd be too much to ask if this
        I believe it is mentioned in the judging guide but I'm not 100% sure. I'll look.
        • Rob A.
          • December 1, 1991
          • 2126
          I know that the "D" is stamped on '66 & '67 original braces...
          • Kenneth S.
            • July 31, 1981
            • 302
            In the 4th edition it simply says: "In 1963 models, the metal braces are 1/4 inch thick. In 1964 models, the metal braces are 3/16 inch thick." There is no mention of a "D" stamp.
            Ken
            • Mike McKown
              Thanks. *NM*
              • Chuck G.
                • May 31, 1982
                • 2034
                Hmmm. I measured the originals on the front of my 63, and they're 3/16 with the D stamp.
                Using my limited math skills,
                .250 is 1/4
                .175 is roughly 11/64.
                .187 is roughly 3/16.
                So, what's the real scoop here? Chuck
                • Michael H.
                  • January 29, 2008
                  • 7477
                  Chuck,
                  As far as I know, the thick 1/4" braces were used for the duration of the 63 model year. Supposedly, the thinner 3/16" braces were SOP of the 64 model year. I don't know if there was an overlap one way or the other but it's possible some very late 63's used the thinner 64 braces. I know a very late 63 #211xx had the thick 1/4" braces.
                  All of the 63 brackets/braces changed part number for the 64 model year.
                  • Chuck G.
                    • May 31, 1982
                    • 2034
                    I went out and measured them again. Used a micrometer. Set it at 6/32 or 3/16. Fit is perfect.
                    Set it at 8/32 or 1/4 and it's way too big.
                    SO, this is a July, 63 car, 19,5XX ish VIN.
                    I've owned it since 1967, nearly 40 years. It's never been hit, and never had a panel put in it, and I've certainly never replaced the bumper braces.
                    I've had the bumpers off and on a number of times, but have never replaced the bracketry. Chuck
                    • Michael H.
                      • January 29, 2008
                      • 7477
                      That's interesting. I had 19,746, an all original car, including paint, that had never been apart. It has the fat braces. It's unlikely that the new style braces would have been "mixed" with the fat 63 braces in production but I suppose anything is possible.
                      • Chuck G.
                        • May 31, 1982
                        • 2034
                        Here are a few pix I took the other day for a fellow member. Chuck
                        • Chuck G.
                          • May 31, 1982
                          • 2034
                          AND pic #2. Chuck
                          • Michael H.
                            • January 29, 2008
                            • 7477
                            Probably impossible to tell in the pic but this brace certainly looks like the thick style. Wish I had one of each here to measure.
                            • Mike McKown
                              I just measured some left front braces
                              3-4 of them. Depending on where you put the calipers they were .171-.179 for the thin ones. I think i measured two thick IB braces, the straight ones and they(it) was .25? something or other. The thickness probably varied a little with each different shipment of steel stock.
