Intake shield and rivets on L79 - NCRS Discussion Boards
  • Jeff C.
    • August 15, 2012
    • 35
    Im bead-blasting my L79 aluminum intake manifold, should I remove the shield on the underside and clean underneath it too? Or should I just stick it back on? If so, what is the best way to remove the rivets and re-install new ones?
  • Steve Wallach
    Re: Intake shield and rivets on L79
    I had my intakes cleaned on my L71 and L36 (One Aluminum, and one Steel). I left the shields in place, and the results were great.
    Cheers,
    Steve
    • Rick S.
      • January 1, 2003
      • 1203
      I haven't done it myself but have read other posts that you have to make sure all the media is thoroughly removed. I also seem to recall that some prefer to remove the shield just to make sure that all the media is removed. I would suggest searching the archives.
      Rick
      • Joe C.
        • August 31, 1999
        • 4598
        Jeff,
        You MUST remove the shield to be sure that no media remains!! Reattach with self tapping machine screws, and red Loctite. New splined fasteners can be purchased, but I prefer the machine screws.
        Joe
        • Mike McKown
          Self tapping screws tend to strip in blind holes
          if you're not really careful.
          • Stephen P.
            • September 30, 2002
            • 116
            Re: Self tapping screws tend to strip in blind hol
            It's simple to just tap the holes for a small screw. I don't remember the size I used. You should still use the loctite.
            Steve Phillips
            • Ken Edmunds
              Or use the rivets still available from Chevrolet, part number 10229247
              • Terry F.
                • September 30, 1992
                • 2061
                Yes, remove the shield. Typically, there will be some junk lef on the inside. I would use the original style rivets or the same rivets if you can get them out without destroying them. You can re-insert them with red lock tight and it will never budge. Your choice though. Best regards, Terry
                • Terry F.
                  • 2061
                  You can very often slip a thin blade under the shied and pry on it and get the rivet to move. Then, carefully grab it and slowly twist it out. Terry
