New exhaust alignment problem 69 - NCRS Discussion Boards
  • george culolias
    I put the drivers side on last week and it came out pretty good. Today I'm putting on the passenger side and it doesn't line up in the center of the frame hole. It's actually touching the frame. This side does have the heat riser and you can see from the pic that the front pipe is lower. The exhaust pipe holder that bolts to the trans seems to be off, as the pipe is tight againt it. Any ideas? What am I missing, there must be an adjustment here somewhere I'm not seeing. Thanks for any insight!
    [/IMG]
    • 11648
    Re: New exhaust alignment problem 69
    Take it to your local muffler shop, and they can tweak the bend to fit the car. Then you'll likely be fine. It still fits far better than what you'd get from Pep Boys.
    Patrick
    • george culolias
      Got it to work with a crow bar
      and a bunch of wood shims. Guess I tweaked it myself,,,thanks for helping.
      • Alan Drake
        Re: System by Who?
        What year car is it on and who made the system?
