C2 U Joint Best " look a like" - NCRS Discussion Boards
  • Alan Drake
    For a C2 March 64
    Need to replace 1/2 and drive shaft U Joints for judging, ie no grease fittings.
    Is anyone making "look a like" - old GM's?
    Relative to points, does one exist which only takes a minor hit or are all bad?
  • Greg L.
    • March 1, 2006
    • 2291
    Re: C2 U Joint Best " look a like"
    Alan,
    I believe that the Federal Mogual Precision Brand P/N 231 are the ones that you want.
    Greg
    • Stephen L.
      • May 31, 1984
      • 3159
      The 231's work in the half shafts.
      The drive shaft u-joint is a different size with an indentation about the size of a quarter. Haven't seen any aftermarket like them...
      • Wayne M.
        • March 1, 1980
        • 6414
        As close as possible to this original '64 U-joint
        On half shafts from a January '64 car (removed and stored since about 1968). numbers are 3705377 and GM 59 B.
        Click this link for view of outboard side. I think the rough cast number is 4118.
          • 43240
          Alan-----
          As far as appearance goes, the Federal-Mogul joints are the closest.
          However, I use only Spicer joints. Most original Corvette u-joints were manufactured by Spicer. Although their configuration has changed, the actual quality of the Spicer joints has improved and they were always the standard.
